MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
- 4:39 PM
- Nov 24, 2015
- Moreno Valley, So California
Very sanitary work there...Leaks, what a surprise.
The U rubber seals the front of the oil pan and the metal cylinder is a spacer for the harmonic balancer if it is loose on the crank. That’s what the little tube of loctitle is for. Check the balancer before you go together and see if it is sloppy on the crank. If it’s tight no need for the shim. Hope this helps you.
