Transmission help needed!
74chargerguy
New Member
11:14 PM
Portland Or.
I recently have completed a motor swap in my 74 charger. It was a factory 318 car with many miles on it. I acquired a lightly used 440 engine and trans from my step father. It came out of a 79 winnebago. I used the hughes conversion mounts for the motor. I had to switch over the tail shaft section of my transmission to work with the slip-yoke driveline. Now the trans doesn't go into park. If it helps I am also using the cable shifter from the motorhome.
I think the park rod may be out of position. I had a similar issue when I changed the valve body on my trans. The rod went on the wrong side of the lever. I had to drop the valve body, use a long screw driver to move the lever while turning the drive shaft to lock it in park, then reinstall the Valve body.
It is good manners to first introduce yourself to FBBO, then ask questions.
There is a wealth of info and good people willing to share their knowledge here.......welcome to the forum and please post pics of your ride.
:welcome: aboard, now hop on over to the Welcome Wagon to introduce yourself and post pictures of your ride.
