Transmission oil pan leaking slightly
o1gnah
5:16 PM
Maryland
I noticed my transmission oil pan has a little oil around the outer edge and a few of the bolds are shining with lite oil. The car does not run and there is little oil in the transmission as this is a project car and just installed the transmission and torqued the cover bolts. Slight gasket visible between the pan and transmission which I think is normal just not the small oil leaking. Causes? How concerned should I be?
I have decided to replace the shift shaft seal. In researching I read their is another seal inside the shift shaft held by a c clip. I believed my leak was from the outer but am not concerned if I just replace that it may still leak. But don’t want to just keep taking more and more apart. Thoughts on culprit?
I bought the tool from Amazon to remove outer seal but I didn’t go well. I don’t plan on removing transmission so all is done under car. I’ll try a small cotter pin extractor soon on outer seal. Do you guys think I need to or should replace inner seal under c clip? Would be very difficult under car but maybe necessary.
Fluid photos are my transmission. The ones with copyright are for reference
On the main trans housing they can leak from the pan gasket, selector shaft seal as above, the filler tube O-ring, and the rear band pivot O-ring(s) at the back of the case.
Be careful with the oil pan bolts, seems they get stripped out often, not sure if from cross-threading or over-tightening them?
I just heli-coiled a trans pan hole yesterday on my 48RE transmission where I cross-threaded a pan bolt last time I had the pan off.
Used the "Big Gator Tools STD1000DGNP Standard Drill Guide Sizes 1/8" - 3/8"" I got off Amazon to help square up the drill bit trying to drill the hole for the heli-coil from under the truck.
The hard plastic pan gasket works good and can usually be re-used.
Mopar also makes an ATF RTV that they use to glue the transmission pans on some of the FWD cars, and that RTV will seal just about anything.
