Trick Flow 295 Heads
I am curious to see what peoples on track results are when they start buying these heads. TF makes good stuff. Little hard to believe these dyno numbers with only a 295cc intake port size. But time will tell!
Seems like a small exhaust valve? Isn’t the common upgrade for oem heads and some aftermarket stuff to 1.81? Does that not matter if they used the real estate to improve the port?
The exhaust port on a trick flow takes a quick turn compared to other bb heads. They get the exhaust out very efficiently. I was questioning it until we put them on a flow bench.
I would trade a larger intake valve for a smaller or oem sized exhaust valve every day. I think intake valve size is more important to make hp than exhaust valve size.
