Mopar Hunter
Found this on the Fakebook.What do the Trick Flow 295cc heads flow?
I doubt that would make for a streetable motor, but I could be wrong lol
You're going to want to do some upgrades on that trans if you are anywhere near 600-700 hp. Most important would be a steel front drum for safety, your valve body should also have low band apply ,a drag sprag from cope or A&A ,good clutches, etc. I bought a TCI ( total crap inside) 700 hp "competition" trans for my 64', it didn't make 100 miles. Check out CRT -Cope racing transmissions. They have do it yourself packages they will give you some insight as to what you really want in your trans.Well as far as I know , other than the full manual valve body its a stock transmission with good parts in it to handle 700 horsepower. Stock input shaft, stock sprag.
The aluminum front planetary gear is another part, the splines can strip out with high HP. The heavier the vehicle, the more stress on the parts.You're going to want to do some upgrades on that trans if you are anywhere near 600-700 hp. Most important would be a steel front drum for safety, your valve body should also have low band apply ,a drag sprag from cope or A&A ,good clutches, etc. I bought a TCI ( total crap inside) 700 hp "competition" trans for my 64', it didn't make 100 miles. Check out CRT -Cope racing transmissions. They have do it yourself packages they will give you some insight as to what you really want in your trans.
I dont know what low band apply is, but im happy with my full manual valve body I've had for almost 30 yearsI build plenty of these. Almost every street unit runs the stock drum. The drum can be a safety issue. Though I've personally never hurt one. A good drum , TF2 kit or manual valve body, quality frictions from Raybetos, Borg Warner, or Alto. I prefer the hard band. 3.8-4.2 lever, $30 46RH trans pan with a billet E bay filter extension. This combo will survive 750hp with ease for years of use. No need for low band apply or a steel planet at this power level.
Maybe I just had bad luck with my planetary gear. The aluminum splines were cracked and falling out on my slow 11 second 4,200 pound car, and that was just foot brake bracket racing, no trans brake.I build plenty of these. Almost every street unit runs the stock drum. The drum can be a safety issue. Though I've personally never hurt one. A good drum , TF2 kit or manual valve body, quality frictions from Raybetos, Borg Warner, or Alto. I prefer the hard band. 3.8-4.2 lever, $30 46RH trans pan with a billet E bay filter extension. This combo will survive 750hp with ease for years of use. No need for low band apply or a steel planet at this power level.
The very back drum is held stationary to take off in 1st. If you don't have low band apply the sprag clutch is the only thing holding it place. If you do have low band apply in your valvebody it applies the rear band and the sprag is holding it. 30 years ago common was the theory that releasing the low band adversely affected the 2nd gear shift so they didn't hold it with the band. The solution was to install a bolt in sprag to take the abuse. But if that sprag gives up like the previous post..the stock front drum turns so fast it explodes. So even with a bolt in sprag..the best safest solution is a aftermarket billet or hybrid billet front drum.I dont know what low band apply is, but im happy with my full manual valve body I've had for almost 30 years
