Hemicbx
Hey all, My car started acting a little wierd so I thought I'd throw this out to see what others think. This might get wordy, but I'll try to get all the pertinent facts down the first time through.
The engine is a 383 w/ a TF, it's got a Carter mechanical fuels pump (the rebuildable type, M4862), and an AFB. From the tank to the carb, there's the sock on the end of the pickup tube, a 3/8 pickup tube, a basic 3/8 fuel filter right there at the pickup, 3/8 fuel line to the pump, the pump, 3/8 fuel line to a see though fuel filter (basic in-line paper type), and the carb.
I just got the car back after 10 years and it was running decent. I ran a few hard pulls through the gears. It was noticeably laying over a little bit at the top of second gear so I decided to rebuild the fuel pump. I installed the complete rebuild kit without incident. It went together nicely. I also went back to the filter right off the tank and replaced that as well as any rubber line in the suction side of the system. Initially it was running great. Noticeably better pull through all gears.
Then after 20 or so miles of running around, it started acting kind of like a vapor lock or a run out of gas. I'd jump on it in first and at the top of first or just after the shift into second it was sputter, practically die, and by that time I was out of the throttle, feathering it hoping it would catch, it would fire & I'd behave like a normal person for a while.
So I get home and look at the pressure side clear fuel filter and it was essentially empty. I could see little spits of fuels coming into it occasionally, but not nearly enough to feed anything. So I figured something had gone wrong in my fuel pump rebuild. I pulled the pump off & apaprt. All looked well. The dry side was dry, the internal valves were all in place and would seal against me blowing or sucking on them (no commentary needed on that statement), so I put it all back together. I measured the fuel pump pushrod at 3.220.
After it was reassembled I cranked the engine through from under the hood and in a very un-scientific fashion I held my finger over the fule pump's suction port. I could feel some suction but very, very light. I should put a vacuum gauge on it to get a number. However, I don't think it's enough to pull fuel all the way from the tank.
I stopped at that point
Before I go dump $$ into a new fuel pump, I thought I'd get your thoughts.
Any input would be appreciated.
-Hemicbx
York, PA
-Hemicbx
York, PA
