33 IMP
- 4:05 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
The CR calculator I use (Wallace) uses a + number for a dish or valve reliefs, a - number for a dome.The following quote is from the UEM catalog that BSB67 mentioned proves his point, and he is correct that Icon expresses a piston with a dish as a positive value making this a dished piston. I concede that this would not be considered a domed piston as I previously mentioned
- "Piston Head Volume and Deck Clearance. Values for Piston Head Volume and Deck Clearance can be entered as both positive or negative values. Negative numbers indicate a reduction in cylinder head volume. Pistons with pop-ups or pistons sticking out above the deck will reduce chamber volume and will usually require a negative number. Pistons with a dish or pistons below deck increase chamber volume and receive a positive value. Located above each picture in the KB Catalog is the value for the piston head volume shown in positive or negative numbers."
While I was wrong in this instance, the below quote from Summitt.com has a note at the end stating some manufacturers use the "+" and "-" values opposite of how Icon does. My mistake was assuming that all piston manufacturers used the same language in describing their products.
"Pistons are available with different head volumes. This is the size of the top of the piston. It is listed in cubic centimeters (cc).
We list the head volume in the way it affects the size of the combustion chamber. This helps when calculating the compression ratio. For example,
NOTE: This method of listing head volume is NOT standard in the industry. Some manufacturers may list a negative value for a dish and positive value for a dome."
- A dished piston will increase the size of the chamber. So it has a positive volume (+).
- A domed piston will decrease the size of the chamber. So it has a negative volume (-).
- A flat top piston has zero volume (0).
- A flat top piston with valve reliefs may list a small positive volume.
Tricky is when a piston has a D-dish for reduced compression, and a quench dome on the other side , for quench with an open chamber head.
