Brewzer67
- 11:02 AM
- Dec 20, 2015
- Menomonee Falls, WI
I am in new territory and am looking for help from the brain trust here. I have my engine back together and am now ready to start fine tuning it. This is the biggest cam I have ever run and my first solid roller so I have no idea what to expect normal baseline numbers to look like.
Here is the combination:
526" (4.375 bore and stroke)
.715 custom tight lash Solid roller by bullet (262@.050 intake, 269@.050 exhaust, 110 lobe separation, installed@107)
Trick flow 270's with Indy max wedge 4150 manifold (flow 378@.700)
850 mighty demon square jetted with 84's and a 2.5 power valve (5.0" to 7.5" vacuum at idle)
Initial timing@24 with 34 total in by 2500 (MSD pro billet)
MSD Digital 6 ignition box
Jacobs ultimate coil
Motorcraft 3934 plugs with clipped electrodes
180 thermostat and runs at 180
93 octane pump gas
7-1/2 psi fuel pressure
I tried 81's for primary jets but then it ran hot going down the road so I know I was a little to lean so I am currently back at 84's.
I am having problems getting it to stay running in gear at idle and can't figure out why. Everything should be close enough to not have this occur but it still does. Idle speed is set at 1050 out of gear and it drops to 850-950 in gear (3800 stall converter for now, 4600 Ultimate converter from Lenny going in next week).
It starts to add advance at ~1250 rpm
It also has a "skip" here and there that seems like I have an ignition miss but I don't know why it would. The vacuum gauge also has an intermittent flutter like there is possibly a valve sticking but I don't think that is even possible as they are new and Larry Smith went over them as well as Mike from B3 so I doubt they both missed an issue with them.
What should my base idle be set at? Am I close on jetting? Too much initial timing? I am getting frustrated so I am all ears. I am trying to tune for 1000rpm out of gear and 850 in, is this what should be shooting for or should I be looking for different target numbers?
93 octane pump gas
