hotrod426
New Member
Go to Eaton Detroit spring’s web sight and go to the spring tech tab and they will explain why you should replace them.
Really didn’t see anything that indicated why you should replace them.Go to Eaton Detroit spring’s web sight and go to the spring tech tab and they will explain why you should replace them.
Quality is remembered long after the price is forgotten.
Chrysler recommends only 45 pounds. Wouldn't torque to yield be far greater than that? Does I/H use the same type of nut?Post #16
If International Harvester says it, you can take it to the bank.
Torque to Yield, like many head bolts
Sam how long has torque to yield been around?? 20/40 years, I don't know if it applies to 50 year old bolts?don't know about Mopars, but IH u-bolts are "torque to yield", meaning they stretch when brought to proper torque. The factory recommends replacement every time. They also recommend retorquing after use.
For extreme use applications, re-use might be risky
Sam how long has torque been around?? 20/40 years, I don't know if it applies to 50 year old bolts?
I usually cut them for quick, easy removal, so.......
I don't get it
