U-Bolts - Reuse or replace?
halfafish
3:10 AM
SW Washington
I'm replacing the springs on my 72 wagon. What are thoughts on reusing the original u-bolts versus replacing them? As info, the bolts look good and I'm doing OK so far getting them loose.
I just reused mine when I put a new 8 3/4 rear in my car. Only issue was when I tried to put them back in the spacing was off. Had to squeeze the ends down/together to go back in the shock plate holes. Same u bolts and same shock plates. Weird
Replace. Metal fatigue is a thing. Factor in the age of the wagon, and the weight that wagon has seen.
I have found in life it is better to do it right than it is to FA then FO the bite.
