U joint
dukeboy_318
10:38 PM
usa
I know I've heard of the special u-joint that allows you to mount a small yoke driveshaft to the larger size ujoint on the the 489 case. Does any one have the part number for that? and will it fit on a 64 ball and trunion shaft
here is a list of different ones you can use.
Spicer 5-527X, Meritor CP527X, Precision 347, CR UJ347, TRW 20226, Napa NUJ240-0369, Neapco 2-0527
And before they made all of these.... I used to use a '57 Olds or Pontiac (?) and swap the caps to the other part of the "+".....worked like a charm.
Duke boy what was the name of the front suspension place that you got the front end parts from. For your dart
