jimmyd
I was driving home wed. night and my '67 Coronet just shut off. Just like someone unplugged it. While waiting for the tow truck I tried to diagnose it. It would crank over just fine. I pulled the #1 plug wire and no spark. I then unplugged coil wire and no spark from coil. I then used my multimeter to check for voltage and had 12 volts at the coil. So I thought I had a bad coil. I took it back this morning and swapped it for another one. I took it back home and hooked it up and it still wouldn't start. After that I went to the fsm and printed a few wiring diagrams and traced the wires out. Everything looked ok. I want to add that when I left that afternoon I had no dash lights. Another thing I did was install a Skip White Electronic Dizzy. I don't know if the dash lights being out had anything to do with it or maybe the H.E.I. module went out. Sorry for rambling. Does anyone have any ideas? I mean it was like you turned the key off when it happened. Thanks in advance for any help, ideas, or guidance.:confused3:
