Thank you both. Skicker, the reasons I'm working over the floor so much are the SFC's I put in, 2x4x.120, the floors had tears due to no reinforcements under the floor for the bucket seats, correct seats but it was a bench car originally and I'm using a 70 k-frame which moved engine/trans back making the tunnel tight plus an added Gear Vendors unit. I initially thumped the tunnel area to clear but it looked like crap so I figured what the heck, do more metal work. Plus in that mix I made up a new t-bar x-member hoop to give the trans more clearance. I at least am not dealing with rot like many of you guys out there. My car is blessed with just minor surface rust, so I'm extremely lucky there. Back in 13 I took some classes up in Pleasonton Ca with Lazze Jansen, Lazze Metal Shaping. He's on YouTube also. I've always wanted to be able to do more than just the usual car/hot rod stuff. The classes were 3 days for the intro and 5 for the more in depth. On the intro you learn the basics about operating an English Wheel, Bead Roller and Shrinker/Stretcher. We made up some basic pieces to learn operations but some of the pieces you make get used at the 5 day session. At the 5 day session you get more in depth making pieces and each of us was doing parts for a 33 3 window coupe. By Wednesday Lazz starts tacking the pieces together and on Friday we ended up with most of a body shell minus firewall, roof skin, trunk lid and the inner structures. During that session you have the opportunity to by the machines from him. The roller and the wheel are fully his from scratch as he's found many others lacking in ability and quality. The Shrinker/Stretcher units come from outside but he does a total redo/tune up to make them better. I bought the machines as I wanted to do that for work at shops. That didn't happen as I ended up just doing mechanical work instead. I did do some initial work for people but it didn't last so I only did my own stuff. I haven't done any of this type of work for 8+ years so the floor is a great exercise on re learning operations which will help me when I do my air intake/air cleaner housing, going NASCAR cowl induction.
Icetech, my plans are to run the car at local track events, Willow Springs/Buttonwillow and some others, Autocross events, maybe a couple of trips to Famosa[ drags] and lots of fun driving on twisty roads.
