Upper radiator hose
kjalltrac
12:35 AM
Sweden Jonkoping
I've read somewhere that the gates 20355 is the hose to use on a 64 b body with big block,
As you can se it is way to short.
The radiator part no is listed as b body 318 1964 radiator.
The car had 383 from the factory, now 440.
Does anyone know which hose will fit?
I'm running a totally different setup 69 belvedere with 451 and non-stock radiator, so I can't help you with which hose will fit, but here's what I did...
I found one that was close, cut I up and modified it to fit with pvc fittings (so it fit perfectly) and then went back and matched one up just right.
This is the one I used, try:
upper 3462114 NAPA 7602
IIRC it's listed for an E-body but works in a 67 Coronet.
I know it's not a 440 or a B-Body, but when I needed a top hose for my 360 powered A100 Wagon, I just took a homemade template to the local Parts Stores, and went through all the hoses until I found one that was close. I ended up with a GM hose that was about 2" too long...easy fix, cut the hose down and tore the label off....fixed. :thumbsup:
you have the wrong thermostat housing to use that hose, the early cars had the taller housing that curved forward. it was made of cast steel.
The original rad in my 64 318 has the top hose connection near the center of the rad. Are you sure the rad you are using is for a 64 sb? How wide is it? I thought the stat housing in 64 is the same for both sb and bb which angles forward but I'm not sure how that would work with the hose to the far right on a bb. I'm looking for the same hose soon.
yes, the no on the radiator is 2445633
The list shows 316, but I believe it´s a typo, maybe 361 is correct?
http://www.rosevillemoparts.com/reference_radiatorguide.php?SID
Using a trimmed Dayco 71281 in my 440 a-body with a 26" radiator.
Radiator is 8-1/2" cap center to inlet center............
I have a 440 in my 74 Satellite but my upper radiator hose goes to the driver's side and I had to use a totally different car which was the Cordoba upper hose for mine.
The local auto parts stores does not have any molded radiator hoses in stock, they used to have about 5-10 years ago, so making a template is pretty much useless.
Interested in what brand and part no. people are using for the upper hose, so I can order and test.
2X on the Napa 7602. It might appear that it is touching the distributor but it's not.
64 Belvedere, big block, 22" radiator.
Found an old hose laying around in my parents garage.
Part no 4266292 / 42095J
This hose fit with just minor trimming at radiator end.
Will post a photo.
Interchange Parts for OE 4266292
Brand Sku Type Name Relevance
Fresh Start 277 Radiator Coolant Hose Fresh Start 277 Array Direct Details»
MOPAR PARTS H0061594 Radiator Coolant Hose MOPAR PARTS H0061594 Array Indirect Details»
GATES 21406 Radiator Coolant Hose GATES 21406 Array Indirect Details»
GATES 21645 Radiator Coolant Hose GATES 21645 Array Indirect Details»
GATES 21912 Radiator Coolant Hose GATES 21912 Array Indirect Details»
NAPA 8602 Radiator Coolant Hose NAPA 8602 Array Indirect Details»
OE 4266263 Radiator Coolant Hose OE 4266263 Array Indirect Details»
OE 4266274 Radiator Coolant Hose OE 4266274 Array Indirect Details»
OE 4266280 Radiator Coolant Hose OE 4266280 Array Indirect Details»
OE 4266819 Radiator Coolant Hose OE 4266819 Array Indirect Details»
OE 4266911 Radiator Coolant Hose OE 4266911 Array Indirect Details»
OE 4266917 Radiator Coolant Hose OE 4266917 Array Indirect Details»
OE 4266918 Radiator Coolant Hose OE 4266918 Array Indirect Details»
OE 4266919 Radiator Coolant Hose OE 4266919 Array Indirect Details»
OE 4401826 Radiator Coolant Hose OE 4401826 Array Indirect Details»
OE 52005814 Radiator Coolant Hose OE 52005814 Array Indirect Details»
OE 52006649 Radiator Coolant Hose OE 52006649 Array Indirect Details»
OE 52006778 Radiator Coolant Hose OE 52006778 Array Indirect Details»
OE 52007167 Radiator Coolant Hose OE 52007167 Array Indirect Details»
OE 52008009 Radiator Coolant Hose OE 52008009 Array Indirect Details»
Durkee-Atwood 41594 Radiator Coolant Hose Durkee-Atwood 41594 Array Indirect Details»
I took the old hose with me for reference.Looked through all the hoses for jussst the right one,,,,,
