using 2000 ram transmission pan
17dodgebros
8:30 AM
pittsburgh
I have a 2000 ram transmission pan I would like to use on my 727. do I need a filter spacer for this,if so where would I get one?
It needs a spacer 2 7/8" thick. Standard deep pan spacers are only 2" thick. I cut one out of a block of aluminum and drilled the 3 bolt holes and the fluid inlet hole using the filter as a template.
