Using Holley Hyperspark distributor with Fitech Go EFI 4 ?
Jack Parmentier
3:15 PM
Apex, NC
Hi all,
Trying to install my Fitech Go EFI 4 (30001) in my '69 Charger w/440 in the timing control configuration. Using a Holley Hyperspark Hall-Effect distributor 565-306,
Seems the Holley Distributor should connect directly to the ECU on the Fitech ? The only difference is the added +12v to power the distributor vs. the MSD magnetic pickup type.
However, I am getting no spark at all from a known working ignition coil....
Anyone have any experience with this ?
Jack
Update --
Found out from FiTech that the Hyperspark distributor will not work with their EFI systems.... it must be a magnetic pickup distributor, like MSD.
So I plunked down my $500+ for a Ready-to-Run MSD 8387 distributor. :o Will see if car starts now with the new one...
I am not going to use timing control from the FiTech EFI system... not worth the hassle for a street rod.
Will see tomorrow if this thing will start/run !
Got the car started & running finally .... :thumbsup: Still have to add vacuum advance & better adjust timing.
