Very CLOSE with my COOLING SYSTEM... couple questions
jenkins71
7:48 AM
Queens, NYC
Hey guys. So for my cooling system I am using a Champion 26" 3-row, and a 7-blade fan off a mid-70's Chrysler. It has aluminum blades and a thermo-clutch.
What I am wondering is what I can use for a shroud? I see the Mopar Performance Shroud on Summit and Jegs, but I was wondering if anyone knows if it will fit around my rather large fan. I think it is about 20" diameter? Anyone know the diameter?
Also, I don't suppose it will bolt right up to the Champion? its a 71 charger, 440, by the way.
Thanks guys!!!
On my 72 Coronet from fan tip to fan tip it's about 18 inches. I have a 26 inch stock Radiator with stock replacement Shroud
Cool, yeah, my fan is a little larger diameter. How much clearance is there around your fan?
I guess I can just buy it and return it to Jegs if it doesn't fit..
Here is what I did on my 63 Sport Fury. I went to the junk yard and found this one from a V/6 Dakota truck and I had to modify it to work for me. Its not perfect by no means but it helps me and it was cheap. Ron
Here is the Summit shroud, mine is not a clutch fan but is an 18" flex, the opening is 20" and works great. bolted right up. 440 26" SB radiator.
