dvw
If its a higher dollar converter send it in and gt it looked at. Though I've never seen a broken converter cause a vibration. It would have to be really torn up.
Doug
Doug
Have u tried unbolting TC push it back off the flex plate ? If vib gone u have answer
I been doing this for 50 yrs. think about it. Flex bolted to crank tc not starter still engages flex starts engine
Works most time otherwise u need. To unbolt real fast as u hit the starter
I'm not trying that!! I'll just take your word for it.
Ya right. Send us a video.Works most time otherwise u need. To unbolt real fast as u hit the starter
You might have 2 separate issues. I have the same engine and had the 2 exact same vibration problems. Idle and 70mph. It took me several months to fix it. A lot of inspecting and replacing parts. But, I finally fixed it. When I changed my u joints, amongst addressing several other things. That I thought would remedy the 70mph vibration. I noticed the inside walls of the rear yoke had the smallest amount of wear from the u joint c clips rubbing against the inside of the yoke walls. To me, at that time. It was an extremely small amount of wear. Thinking, no way that’s causing the problem. I took the rear yoke to a driveshaft shop several months later when I was about to give up on chasing the vibration. They pointed out the c clip wear grooves that I already was aware of. But, didn’t think it could cause a problem. Rather, than buying a new rear yoke. They took a punch of some kind and made little dimples where the wear was to expand that area. Fixed my 70 mph vibration. Don’t under estimate yoke wear on the rear or front yokes. The front yoke splines wear too. People bend the ears over the years incorrectly installing new u joints. I would have driveshaft balanced if I were you. If that doesn’t work. Look at replacing a yoke at a time. Then I would move onto tailshaft bushing and bearing. As already mentioned. Harmonic balancer and torque converter not being balanced for idle vibration. That’s important because a 360 is externally balanced. People swap 360’s into 318 cars. 318’s are internally balanced. People install 318 balancers on 360 engines.
Most importantly, check that all engine mount bolts are tight enough. People install engines and forget to tighten them sometimes. Engine mounts bought today are North Korean, junk. They split and don’t last longer than several months sometimes.
While the car is idling, observe the engine mounts with a good phone camera. You can see, if they are split or moving a little.
