Want to convert my 67 Charger's hood release from Exterior to Interior! What do I need to convert mine?
2fast4u8
12:02 AM
Kansas
From what I see I have to have the cable set and a different hood latch set?!
I defer to you all.
Get all the stuff you need from a '66 Charger. They had inside hood release.
Yeah, just trot on down to your local pik-a-part and pull that stuff off a '66 Charger !!!! LOL!
Which pik a part is that again??? :lol:
The cable you can get new. Then you need the latch mechanism, the handle and bezel, and the clamps / return spring
Then the bezel won’t fit correctly in the dash.
Possibly you could go to a farm supply business or speed shop. Get a long choke cable and bracket. Create your own.
The 66 dash bezel hardware will not fit correctly. You need a 66 dash to do it correctly, then more hassel’s.
I suggest mounting the release handle on the bottom left side of the steering column.
I am replacing the dash cigarette lighter with a hood release pull in my 67 but keeping the original exterior lever. Kits are out there for the cable and find a way to attach. Get original hood release handle and bezel for the inside from a parts car or someone on here. If you really want, also get the upper cross support with the correct hardware.
Now you are unoriginal heh heh. Very good idea! I will still use our lighter socket to plug chargers phones in. But could plug into the rear one.
Offside, one of our 66’s has a metal block off plate so it cannot be opened from the grille side.
Yeah, also unoriginal in that I added a C body rear bezel to my console that has the light and cigarette lighter for charging.
I've owned a lot of 66 and 67 B bodies.
Inside hood release is extremely uncommon.
I imagine someone, somewhere has saved one, though.
I have a 66 charger and I’m not sure what it would take to transplant it to a 67. I’ll say this though, there is really no security aspect to them You can reach under the hood and still unlatch with your fingers In fact I end up doing that most of the time because I forget about the remote release.
So for me , no real advantage to it……but no , you can’t have mine.
MY 66 had most of the remote release removed and lost before I got it. I was able to buy a new cable, Handle, Rubber Bulkhead gromet online. I obtained the cable hold down clamps/brackets for a nominal sum from someone I think on Facebook. I haven't been able to find the correct return spring though. Got ripped off on Facebook trying to purchase one. I'm thinking about just using a spring from the local Ace.
I posted picture of one of our 66’s with the block off plate to prevent opening of the hood. That was on Sunday in the 66-67 category.
That’s what I did and the spring works fine. I did have to take coils off a couple at a time to get it right.
