Was running 30mins ago Now No Spark??
Dlarge
10:38 AM
Riverside,CA
Adjusted my breaks this morning and took it for a drive, everything was good, parked it and came back 30mins to pull it into the garage and now has no spark!! What happened?? checked a few things, cap and rotor, coil, and resister not getting spark!! But i noticed when i turned the key to off position i have power to the resister and coil!! Anyone know whats up??
sounds like a screwed up switch. If it's hot with the key off jump out the starter solenoid (disclaimer:in park or out of gear) on the firewall and see if it starts?
Possible silly comment, but are you sure of the switches position? Sometimes they rotate in the dash. How's the ballast resistor? There's also a fuseable link off that firewall bulkhead connector. That seems to be one of the first things that goes bad every time I get a new Mopar. Those connectors are famous for corroding and melting internally as well.
Try this test
Turn the key on, and hook your test lamp or meter from the coil low voltage terninals--one at a time--and the other test lead to ground.
You should get a light or voltage on one side or the other, maybe both if the points are open. (key on)
If you do not get power at the coil terminals, go up to the ceramic coil ballast resistor, and check both terminals of the resistor with your lamp.(key on) You should get power with the key on on both sides of the resistor. If you only have power on one side, the resistor is bad. If you don't have power on EITHER terminal, you have an ignition switch or wiring problem
If you DID get power at one or both coil terminals, here's next:
If you get power on BOTH sides of the coil, that means that the points are open or are not making contact.
Now put your test lamp on the dist. side of the coil, that is, the low voltage terminal on the coil which goes to the distributor
Bump the engine over--easiest way is to short the starter relay on the firewall--and see if the lamp blinks off and on as the engine cranks
If the lamp stays on when cranking, that means that the points are not closing. They could be corroded, not set correctly or the wire to the points may have a break in it.
If the lamp blinks when cranking
and still no spark, then you might have a bad condenser in the distributor, or the coil may be bad
(If you leave the key on for long periods, it can heat up the coil or resistor, and damage or fail them)
On the other hand, if you do this test, that is, lamp on the dist. side of the coil, and crank engine, and the lamp STAYS OUT when cranking, that means that the points are not opening, and probably need adjustment, or that the wiring in the distributor is shorting to ground.
I guess you know how to set the points? I did not used to set them with a feeler gauge, just a dwell meter. You probably want to set them with a feeler, 'till you get the hang of it. With the points on a high spot on the cam, adjust the points to the proper feeler setting.
Ok I have a feeling its a bad coil or dist more than likely the coil... We replaced the b resister and its only hot when key is off....
The coil is hot when key is on and off, we also checked all wires, grounds, connections, and cleaned em....
So how can we make sure that the coil is bad before buying a new one..... Thanks
So thanks everyone for your help and info!! I ended up stealing my buddy's coil out of his Duster, and sure enough started right up!! Thanks guys!!
