welding passenger pans
MADCIMA
5:44 AM
italy ravenna
I'm soldering the patches, what diameter of wire do you use, 0.8 or 1?
Mig welding. Probably a .025 wire
Ya, if MIG welding, .023 is usual for 18-20ga auto sheet metal... .030" will do but it's more difficult.
You are brazing? I did that once on a Cuda in the early 80's because it was all I had at the time. Buy a cheap mig welder and go that route instead.
I suspect he's translating from Italian and it substituted "soldering" for "welding".
I should have noticed that right off... so you want ~.6mm wire/.023"
If mig welding, no bigger than 0.8 mm. Prefer 0.6 mm.
Yep ^^^^^^, .030 and crank the heat up.
