What alternator you guys running?
greenmachine
12:47 AM
portland
I know you guys run Holley sniper, big fuel pump, dual fans, stereo, etc. what alt you running to make this work? My alternator can’t keep up. 69 bee. 440.
If you are considering adding additional loads as you mention, chances are the stock wiring of the car needs to be modified as it was designed for the current rating of a stock alternator.
This one.
I have been using this one and have no complaints whatsoever. It has outstanding low RPM output as well as increased overall output. Obviously I made required changes so that I wasn't passing through the amp meter. I actually had already switched to a Ron francis conversion for electrical before I switched to this alternator. It's a really nice unit, and has visual appeal as well. 10 years, no issues.
Hey fellow mopar lovers
I’m in the process of upgrading to power master 165 A one wire , I’m looking to take load off the ammeter and I also know I have to do the bulkhead bypass , I’m also doing the “ big 3” upgrade under the hood using 2 gauge cable . I’m also putting a 200 amp manual reset fuse / circuit breaker on the power cable from alt to bat
Any input or advise plz
Denso internally regulated.
