No, cannot remove the stands. Pressed on Aluminum it appears.
Appears to be big blockCan you confirm there for a BB or SB? If SB could be W2 rockers due to the offset rocker. 440'
Not all older BB had adjustable rockers. There were mostly with stamped steel rockers with the aluminum stands.
Lol! Story of my life! 440'I made myself a set of the bolt-on stands, much stronger, more metal, made out of 6061 instead of the factory casting. Really nice. Put them away till later when i would need them. Its now later. Cant find em. S#!t.
I can’t tell you exactly what those came off, but all early BB mopars had the bolt on stands.
I’ve worked on very little of the early stuff, so I can’t say for sure...... but I believe anything that used the bolt on stands also had the adjustable rockers.
