What do you guys think
65NUTCASE
5:28 PM
p.a.
OK I put a pertronix IGNITOR III in my 65 . It said to bypass the ballast resistor but I wanted to keep the factory look ! We made this out or plastic to take its place. It uses the factory mounting bracket and the spade connectors with an 8 gauge wire between them . Will fill the back with clear epoxy . Now I got all the juice.
Instead of plastic could you gut the porcelin and use the 8 gauge? Cool idea though.
Yep we just wanted to see if we could do it thanks
I used an old porcelain one, gutted, with 10 ga wire soldered to the connections and sealed with epoxy resin.
