What is this Gray oil?
Mopar Hunter
4:38 PM
Mountain Home
On my friend’s 383 with 906 heads rocker bolts, both sides of the front rockers. First time they’ve ever been removed. The rear other bolts on both sides look fine. Head gasket leaking?
I have an old Chevy that’s full of that crap- 1963. Never been apart. I did a fuel pump and scooped out this antiseize looking grease/sludge with my fingers.
I chalked it up to old fuel and oil residue. Lead maybe.
But I’m curious what the consensus is here.
I've seen that too and the engines were pretty well worn.....and have no idea why it only shows up in certain areas.
Its in the wrong place to be bearing sludge. I've also seen that on original builds. I think its some sort of assembly lube. FWIW, those particular bolts don't get much torque.
Bottom of oil caps , even on newer cars
Was always under the impression , condensation mixed with the type of oil that sits stagnant for along time ???
Tan Brown Gray In Color
They say it's Lead, whoever they are. I have seen it on original engines that haven't been apart. Will be on all the bolts inside the engine.
I ALWAYS find this grey gooey crap under bolts as I disassemble and clean engines. It is a by-product of the oils of yester-year. The engines also give off an "Old" smell too when they are taken apart and washed. I would have to say that after about the 80's or so you don't see it anymore. If an older engine is not like that, it has likely been disassembled before.
When I blow out bolt holes, I get that **** all over my arms and face...
