bingoDoesn't matter, buy what you want, it's your $$$
it's a waste to no have the cfm/flow, no matter the look...
worried about the wrong stuff
you should want quality & a better part
but you do you, I'm done
Ding ding ding, totally forgot about it, coming from small blocks has its differencesFuel pump pushrod
I think with a 3.91 stroke and 2 lbs less per piston/rod assembly, these will rev pretty fast/free in a 383!Well, took it down and when I took heads off 4 of the valves were broke off from the stem, no sign of smacking piston, I just think time got to it and one of the lower bolt holes on one of the heads is cracked, so guess those aren't happening. Blocks still sitting in mmo trying to unlock it. Its going to machine shop, im probably going to take it to blueprint deck height and everything, and probably bore it 30 over cause I have no forged pistons otherwise. Hopefully block can take 30 over
Only thing is i dont understand is how im supposed to have any compression really, even the icon 687s are 28 thou lower compression height almost, and their 10.4 to 1 on a 80cc head, I dont know if that's good for an aluminum head, I've heard they need to have higher compression to perform well?
Now, as for why I want a 383 as opposed to a 440? I want to be able to rev freer and faster, without having to drop as much coin
Also, while nitrous works better with more cube, a 100 shot is gonna still at the end of the day add 100 horse
Spot on! A year ago .I started with bare block, factory crank and rods for a 440. After boring .030, 440 Source heads, Hughes can, JE Pistons, Doug's headers, Performer RPM, and a dyno tuned Holley.....and some other items WITH machining and the build ....10k. Oh, that also included the dyno pulls.Better start saving that 10k for the rebuild.
Were the JE pistons custom, and if they were, how much did they run you and did you order any trick deals with em, or just pretty standard pistons?Spot on! A year ago .I started with bare block, factory crank and rods for a 440. After boring .030, 440 Source heads, Hughes can, JE Pistons, Doug's headers, Performer RPM, and a dyno tuned Holley.....and some other items WITH machining and the build ....10k. Oh, that also included the dyno pulls.
I don't think they were custom. $700.00 JE # 213455 and motor is a roller (Cam, lifters, Mancini rockers)Were the JE pistons custom, and if they were, how much did they run you and did you order any trick deals with em, or just pretty standard pistons?
Also did you use a roller or flat tappet cam?
Hopefully going with a 68 383 rotating assembly i can get for cost of shipping so no need to balance, around 180$ and going flat tappet over roller will cut some of that price down, but yea I have a complete engine, while heads wont work most everything else shouldI don't think they were custom. $700.00 JE # 213455 and motor is a roller (Cam, lifters, Mancini rockers)
Yeh ...a real fast track to 10k but remember a bare block means bare block. No hardware or any ext parts like pan, tray, pumps,timing cover,water pump housing,....nothing. Now it's in the car and running. Dyno'd with 510hp and 540Tq.....I had to stop there with the limitations on my trans and rearend.
If you look up Chris Birdsong on YouTube, he's a firm believer in 383s but like some have said....if you start from scratch the costs could be nearly identical. The whole flat tappet lifter failure chased me to roller but flat tappet is probably half as much in cost.Hopefully going with a 68 383 rotating assembly i can get for cost of shipping so no need to balance, around 180$ and going flat tappet over roller will cut some of that price down, but yea I have a complete engine, while heads wont work most everything else should
The main reason I went big block also is id like to go with another setup for motor, I dont like how my PO setup my 340, I think its a poor combination. To change it though is god awful expensive for small block, i will happily go with 440source for almost anything I need, especially for things like a oil pan or something
If there was like a 440source for small block my opinion would be different
I'm personally not a fan of 383s and don't get why anyone would chose to use one save for a numbers-matching deal. I certainly wouldn't put one in favor of any 340 nor spend a dime to rebuild one to stock specs.
Based on my own direct experience, I had a basically stock one in a '68 Coronet 4 speed ('68 10:1 flat top pistons, 335HP "Roadrunner" hydraulic cam, stock "452" heads) that I drove for several years that couldn't get out of it's own way. Wouldn't rev past 4,500, (yeah, 3.23 gears were too short). But even with full tube headers, aftermarket intake and EFI control it was still a dog. Better cam and gears would have certainly helped increase the fun factor.
That said - I've posted this clip several times but here's a 383/438 I built for a friend a few years ago. All in for around $7,500. That's 2020's real world cost for parts and machine work. No labor charges since I taught him how to build it in my garage. I probably also gave the guy at least $1,000 worth of my own parts.
The engine is based on a .060" over 383 block. OOTB Stealth heads, 440 Source 3.75" stroker kit, mild Hughes hydraulic RV cam, Performer RPM intake, Comp Magnum rockers, TTI headers. Made around 450hp/475lb ft of torque, revs to 6,000 rpm. Would have made plenty more with a more aggressive cam and intake. Nothing wild, 100% street friendly and would easily go 12s in a B body with a better cam and steeper gears.
So the two builds are similar, I assume aside from displacement? So a mod done to a 383 on a a body will have the similar results as the same mod to a b body but with a 440 instead, if that makes senseI like the 383s. Best I've done is a 10.50 in a light A body. Conversely, the 440 in my Charger has gone 10.50s so far.
Essentially they are the same motor. The 440 just moves the piston further down the hole, creating more tq. Hp gains are slimmer. The 440 in a porky b body is the way to goSo the two builds are similar, I assume aside from displacement? So a mod done to a 383 on a a body will have the similar results as the same mod to a b body but with a 440 instead, if that makes sense
Want to make a profit on this 383? Don't put one dime into it. But get it running and show the buyer how good it is. There is your profit.
What does your car weigh? Too much gear is a band aid to get the car moving. It is the Stock eliminator recipe to ET, but lots of valve spring and maintence costs. Those engine don't last very long.
Go price pistons for a 383 block and 440 crank.
