what year parts do i ask for when wanting ECM and other newer components on my 67 coronet
mopar440bbody
6:30 PM
louisiana
i am still having starting problems with my 67 , we did get some fire out to the plugs but no start. however we did find choke plate stuck and plugs on the 2 we pulled looked full of gas. gona try start in the morning see if it will crank . and i guess change the plugs i just got the car so i knownothing about what has or hasnt been done. i cant under stand why it stalled in the 1st place only problems i found was timing dog (keeper) was loose and had little value ping, on my 1st test drive. motor sounded strong had power and went in all gears.
but as far as parts for ECM and Dist. i ask for 1973 or newer? mopar only makes a few diff models but i am sure to run into problem sooner or later.
Do you have a stock Chrysler distributor or an aftermarket type?
You need to figure out what components you have now in order to ask for the correct parts.
hey the dist. looks like a stock chrysler nothing fancy . looking last night its a single magnetic pic up and i had the 5 pin ECM and i bought a new lifetime coil when the stalling st arted .
new coil after stalling started, my plugs could be fouled with gas we found choke plate stuck closed. i just got 8 new autolites 85s for it. might change them later after it not so hot out there.
