whats a good trick to get glue off roof
jess
11:22 AM
minnesota
i took my soft top off and now i have glus and fuzzys
on the roof i had a lil bit of jet strip left so i have been useing that
but it is messy and slow
anything else work better?
grinding it off wont work very well the glue is not hard and brittle
i will try the razor and thinner tomorro but i got about half of it done with jet strip
I know this is dangerous ,and im not saying you should use this ,but gasoline works the best .A friend of mine does tops and that what he uses.
gas it might be cheaper to use thinner lol
i will give them both a try since i got both
paint scraper and heat gun will remove it completeyl with no residue
tryed gas and thinner
didnt work good at all
i will try a heat gun next
Try some of the 3M adhesive remover. That stuff works fantastic for every type of adhesive I've run across. Bought my last can at Napa.
i will pick up some 3m
that should work i have had very good luck with 3m stuff
thanxs
i will let ya know how it works
the 3m worked good still gotta scrape it off but worked the best by far
altho that stuff isnt cheap it dose work
It's pretty amazing stuff and it doesn't hurt the paint. I find lots of uses for it besides removing adhesives. If you are winding up with small "wads" of glue, try using more and change rags frequently. Yes it does cost alot ....
