This is from the 1966 Dodge service manual
Camber Left +1/4 to +3/4 degrees (+1/2 preferred) Right 0 to +1/2 degrees (+1/4 preferred)
Caster Manual steering 0 to -1 degrees
Power steering + 1/4 to + 1 1/4 degrees
Toe in 3/32 to 5/32 1/8 inch preferred
Height 1 7/8 + or - 1/8 inch
thanks for your help!![]()
an offset bushing installed only on one end will also effect castor as well as camber.Im Thinking of ordering a set of Offset bushings now. do i need offset bushings in the front and rear on control arm? or can i get 2.5 degrees with offset on the rear? Thanks!
I have a supplier back here home that have only one set ( two bushings) but im not sure if that will give me the desired value.
Are those specs the same for a 67?Camber Left +1/4 to +3/4 degrees (+1/2 preferred) Right 0 to +1/2 degrees (+1/4 preferred)
This ^^^^..... my preference has been the second line for many years.Here's a chart that will get you there. View attachment 1858518
On my 66 Belvedere, I was able to get more camber than 'Max perf street' and liked it! Never did measure caster but the steering wheel came back after making a turn and turning loose of the wheel. It also did fine at high speeds and didn't have orbital float while going through dips etc. and ran 1/8th toe in.Here's a chart that will get you there. View attachment 1858518
A good alignment tech doesn't need factory specs to do a good alignment. They know what angles work and which wear tires.On my 66 Belvedere, I was able to get more camber than 'Max perf street' and liked it! Never did measure caster but the steering wheel came back after making a turn and turning loose of the wheel. It also did fine at high speeds and didn't have orbital float while going through dips etc. and ran 1/8th toe in.
Test drive it....what works well for one car might not work so good for another. Build tolerance wasn't that great back then.Are those specs the same for a 67?
After getting rooked by a 'known good alignment' tech (and more than once) I 'learnt' how to do my own......NASCAR style lol. A machinist level helped tooA good alignment tech doesn't need factory specs to do a good alignment. They know what angles work and which wear tires.
