petieg383
Power steering started to leak. It basically drained the entire reservoir overnight. It looks like it's leaking from the high pressure line where it connects to the actual steering box, not the reservoir. I pull it off and see this fitting. It's totally hammered. I'll replace the line as well, but if you look at the tapered part of the fitting you can see it's banged up. That to me would cause it to leak.
Where can I get a fitting like this? I've tried local parts stores, even the local speed shop. No good. Some searches on the net aren't getting exactly the same style fitting. For the record it's 1/2" 20 on both sides of the fitting.
A few questions:
Is this the correct fitting? Will something from the AN world work?
Please help. The car is parked until this BS item is replaced and it's driving me crazy not to drive because the weather is so damn good!!
A few questions:
