where to buy a clutch assembly for a 73 RR 400 cid, 4speed trans
b_body_hopeful
9:16 AM
colorado
I am looking for a new clutch assembly. Mine is slipping and does not grab cleanly from a stop.
Can anyone direct me to where I can purchase a cover and pressure plate assembly w/clutch disc for a
1973 Road Runner?
It should be an 11" for a 4 speed 23 spline 1"
Thanks in advance.
If you don't have a local speed shop then Jegs,Summit or any other speed parts outlet can sell you what you need. Now would be a good time to upgrade the stock clutch to something more durable:sign13:
After years of pounding I found out that I have an over-the-counter generic from Napa. Good feel and long lasting. 440. I don't ride the clutch, but it is not coddled. I stripe parking lots when I can and it is (relatively) safe.
Is there a bulletproof way to know if I have a 143 or 130 tooth flywheel? Don't want to purchase wrong parts.
Been reading but FSM does not specifically tell me which one I have.
a 143 will have almost 36 teeth in 90° of the flywheel-mark it and count
a 130 will have 32.5 teeth
