where to find a speedomter cable for 1964 torqueflight transmission?
Evan Frucht
12:07 AM
Los angeles
where can I find a speedometer cable for my 1964 fury. original 318 pushbutton torqueflight. the cable is roughly 6 feet or so.
does anyone make these new, or do I have to find a used one?
I bought one that said it would fit my 64 fury, but now that im trying to install it i can see its wrong. its got a different style end on the transmission side
I don't know if 64 and 65 are the same, but I've been told that a speedometer cable from a '68 Camaro will fit a 65 Belvedere.
I've ordered 65 parts for my 64 when there was no listing for a 64. The only one so far that didn't come close was the brake booster.
I've been told a 68 Camaro speedo cable will fit an A833.
Like 64 BEL said, call Joe Suchy. I got mine there.
Yes, '68 Camaro fits the later, bigger 727 and 833 speedo drive. Perfect length, too. Not sure what your '64 has. Can you get a pic?
The '62-'65 speedo cable end is different than the '66-later.
thanks, that is the correct one. I ended up just fixing the leak on my old beat up cable and just reused it. because those are so pricy, I figured my old cable is probably fine to use for now... it just doesn't look to hot! if they were cheaper I might of said screw it and just bought a new one. but as they say- " if it ain't broke don't fix it."
