Which Holley carb for my 383?, XE268H compcam, 906 heads
__Larsson____
9:00 PM
JONKOPING
So i have decided to go with a Holley instead of a EB, but which should i go with?
Now i have the 770 Street avenger, it goes like hell when i kick it but tends to get a bit to much fuel when i take the foot of the pedal, and if you cruise slow and push little bit on the pedal it tends to like hesitate, and the choke got fucked up so thats gone and i do miss it.
So which size carb should i choose?
I have seen a post with a similar egnine setup and many of you said 750? Would that give me the best on all levels?
I am going to be using a similar cam with around 9.3 compression and iron heads. I'm likely to use my Holley 750 Vacuum secondary OR a ThermoQuad.
750 dp
Works great with almost any 383 build
(unless your REALLY building something wild:rolleyes:)
