Which plugs have others had the most luck with on Indy Heads..
67coronetman
6:45 PM
Blount Co
I am just Curious what other have had good luck with on there Indy heads i have been using Autolite plugs work ok so what say you what have use used..
I use NGK. They are cad plated which makes them easy to read on the first hit. Made it's quickest pass ever last fall on 2 year old plugs, 9.12@147
Doug
I have used Autolite and NGK plugs and the performance was the same with both plugs. And both seem to last about the same amout of time before I pull them to clean which is about a year. Ron
