Whistling hissing air sucking
joseph p.
9:16 PM
walnut creek ca
Hello to all,I got a 1968 383 with a 6 mos since rebuild of my Carter Avs 4bbl,ran perfect, started this hissing sound,too much air induction,maybe the butterflies are stuck open???,thanks for any suggestions.
1969 satellite with 383 block.
I will second the choke comment....if that engine is warm....your choke is all wrong.
For the whistling....start removing hoses 1 by one and capping the input. That will rule out any hoses. Don't forget to do the choke pull off diaphragm hose.
Did you change a base gasket?
Use a stethoscope to pinpoint the noise if the above does not work. Pay attention to the throttle shafts where they go into the carb. Place scope there.
Slightly re-tighten the carb bolts to see if a change.
yes new base gasket.
