The diameter is the same. Some hydraulic flat tappet vendors show the same part # for LA series and B/RB so This isn't a dead issue. As I mentioned, there needs to be a way to secure the roller lifters to keep them square to the cam and to NOT rotate. The valley area would need to have holes drilled and tapped to mount the "spider". The Magnum version would not fit due to the larger size of the B/RB block. You'd have to make one custom.
