Will this cam work with my application?
67charger383
8:51 PM
Maryland
30 over 383 with TRW 12-1 dome pistons and 915 heads, 4.11 suregrip rear end
Racer Brown 485/286
It’s a 1970 special service Chrysler part (pre direct connection)
Part number 3412073
It will. Question is whether your wallet will happily fund he fuel for it.
IMO, the cam is not the big issue, SSH-25 was a good cam in the day. 12-1 dome pistons will need better gas. If you have access, you could mix 110 race gas or 100 aviation fuel.
That will be fine on E85. It's way old school. But will perform pretty decent. Keep the rpm down to a reasonable level. itll live a long happy life. Find a loose converter.
Doug
What do you mean by that? Are you sure? I am worried about compression, and it will be run on E85
Oh E85.... we don't have that option around here. I agree with Doug, should be fine. I thought E85 likes 12:1
So the alcohol content is high enough to slow the combustion rate down enough to handle the high static CR?
depends on the dynamic compression with the cam
alcohol cools
at your cr you should be good
14 takes a big cam
we ran 60 pounds of boost with LOTS of alcohol 50 years ago with a stock wedge chamber, tight quench and not to big of a Winfield cam
