Winter plans for the Roadrunner
426Roadrunner68
2:55 AM
Pittsburgh, PA
First things first, fix the vacuum leak. We are going to use a smoker/fogging machine to find out where we are leaking crankcase vacuum. Did this earlier in the year and it was coming from the valley plate. Pulled intake, made some modifications and boom, vacuum where it should be. After one race, pulled covers to check valve lash, after that, at Norwalk for mopar race, vac was down again. Tried to see if we could do something at the track but no luck. So we WILL fix the vac this time. The valley plate is a thin piece of aluminum that is fastened to the bottom of the intake with Allen headed cap screws and silicone. So if the vac leak is coming from there again, we will be using an Indy valley plate that needs modified to be run with the manifold we have. We also had some vac leaking from the valve cover bolts which we fixed with aviation sealant. The valve covers we have are aluminum valve covers which are nice looking but they’re cheapies with 5 different length bolts to make them work. Plus we have to drop the passenger side shock to get the one cover off. They’re a pain in the butt. I got new Ray Barton valve coming which will work with his rocker system and hopefully be less hassle than the current ones, and hopefully seal better than the current covers. If we have to pull the intake and switch valley trays, we will pull the engine out of the car to do that on the engine stand. That’s first. It was crazy how much the car slowed down when the vacuum went down from 10” to 1”. It was worth .05-.06 in the 1/8.
Next, we got new valve springs coming to put on. Had to order a very expensive on head spring removal tool from Barton that is made by Buxton. Should be in this week.
We almost pulled the trigger on a Stage V dual carb manifold with 2 edelbrock carbs so my dad can run in the Hemi class at Mopar races. But we decided to stick with the one dominator setup since it’s a bracket car and works very well as is. No sense in spending thousands of dollars on a new setup to race in the Hemi class 2 times a season.
If the engine comes out and goes on the stand, will likely get a Peterson primer pump to put on so we can prime the engine without pulling the distributor.
I had trouble with vacuum leaks that I thought were at teh corner of the tray. Turns out it was the very upper corner of the head gasket. Not much clamp load in that area. Now during builds a little Ultar Grey is added at the top 1/2" or so of the head gasket surfaces. The first time fixed it without pulling the heads. Added Sealer under the lip of the head between the front of the block china wall and the bottom of the head gasket.
Thanks Doug. We typically run ultra grey or optimum at the corners of the head gaskets. I’ll surely be looking there closely though when we fog it down this weekend. His valley tray was the culprit along with some of the valve cover hardware last time we fogged it.
His valley tray is attached to the manifold and is just simply a thin piece of aluminum that is fastened to the manifold with Allen cap screws.
His new buxton on head valve spring removal tool showed up today. He told me he doesn’t know how we are going to get the exhaust valves out without removing the engine. Guess we will find out Saturday and I’ll surely give you an update on what we find.
I've done Hemi springs in the car years ago. Used the standard bolt on the shaft tool. But instead of the straight handle I used a curved handle for setting lift bars on a trailer. Drilled a hole and welded a nut at the bottom. Then ran a bolt in so it wouldn't pivot around on the tool base.
I’m just curious why crankcase vacuum makes more power?
Interested myself to hear other POV’s on this.
What makes sense to me is: A) less atmospheric pressure on the bottom side of the piston. With a vacuum condition, the piston is technically being sucked down in the cylinder from the crankcase. B) it sucks the rings securely to both their lands and the cylinder wall, creating better ring-seal.
There some logic there. But how come it feels "Suspicious?" lol.
The older I get, the more "Suspicious" I feel.
Then there is also the increased suction as the piston goes up, cancelling the gains on the down stroke.
Reduced crankcase gas density could lower rotating resistance, I suppose.
my understanding is it is really all about ring seal . Which is why they use a low tension/thinner (?) ring set. Less ring drag but vacuum assists with seal . Mild side effect is potential to reduce oil weepage/leakage . Motor must be built to take best advantage of it .
Little to be gained under 6000 most gain above 7000 . Some swear by them others less so .
Tex
For sure It's about ring seal. Assists with ring flutter and helps the ring seal in the piston groove. Pumping loss due to reduced crankcase pressure is an additional benefit. You won't find a high end wet sump engine without one if it's allowed by rules.
Thanks Doug. We are going to see what we get into when we get to it. I’ll surely pass on this idea. We got tied up Saturday and couldn’t get to it.
This is my understanding as well regarding the crankcase vacuum topic. Thanks for posting!
