Won’t start, won’t crank
Qwick68
1:44 PM
Connecticut
68 Charger won’t start. Newer battery fully charged, brand new starter. Car sat for two months and now it won’t crank. Turned the motor by hand via crank bolt. Sound like the starter wants to turn the motor but engine won’t crank. Connections are good, fluids are good…just put it away a couple month ago and now nothing….
What is the voltage on the battery? So you get a click like the solenoid trying to kick the gear into the flywheel? Battery to starter wire solid on the connections?
Get a jump pack and try and jump it.
You need some test equipment if you don't already own it. I would have a DVOM, a set of jumper leads and a remote starter switch if working alone. The harbor freight stuff would be ok for checking most electrical on old cars.
Yes that’s exactly what it’s going. I will have to check the voltage, the car is on a lift in the garage. I did try and start it with the jumper pack on as well but made no difference.
How old is the big cable from the battery to the starter ?
I went through the same thing and it turned out the cable was all green inside the end the bolts to the starter
Another cable and all was good
If the car is on a lift try to get a jumper cable and go from the plus on the battery to the nut that bolts the big cable to the starter and try the key again will tell if it is the cable
I’ll give it a shot in the next day or two, thanks
And if that doesn't work same deal on the negative.
Hell, just get a booster pack and put the + on the starter lug and negative on the engine casting and hit the key!
Based on what you stated in original post, sounds like it was fine before 2 months of sitting. Batteries can be fickle when they are about to, or have already gone bad. Truth about your battery will be told by measuring what the battery volts with an analog or digital meter WHEN you turn the key to crank. Curious that all of a sudden it won't crank. Try disconnecting your questionable battery and connect a known good battery. Might just be your battery is defective.
What about the neutral safety switch and the starter relay? Did you try jumping across the starter relay?
If the sol 'clicks', it means the NSS is ok. With all the things that have been tried so far, I suspect faulty starter.
the last time I nurtured someone through this process, it took weeks to discover the battery was in the trunk, and the wires running to the starter were lame. If the engine turns by hand, it's either the (starter) motor or the juice. It isn't complicated.
Do you have any device to measure voltage ? Did you try a different battery with yours disconnected ?
ok, this needs explanation
Cold starts and warm up periods are where most engine wear occurs.
If you're not driving it you just idle the thing until it gets warm doing more harm than good.
Likely filling up the exhaust system with moisture as well.
Mine get driven as late as possible driven right before storage and put away at operating temperature.
Cap off the carb and exhaust openings, lift the negative cable and sit for 5 months or more.
Starting periodically over the winter in the northern climate is not a good idea. I have a couple videos of them running as a fix for the winter months.
