Yellow wire help
RobsRR
9:49 PM
NC
I just replaced my ignition switch on my 71 Plymouth Roadrunner to correct a voltage drop issue. I can't remember where the yellow wire plugs into. The one for the ignition lock light. I searched the wiring diagram and don't see it. Thanks ahead.
I believe it goes to the time delay relay. Small metal "can" shaped object.
the fuel relay was an option ( not common ) but the rest is there. I have a pic of the full assembly with the low fuel warning light, where is shown the delay can... was searching a pic of just the seatbelt/ignition light but couldn't find it but however searching around found the 68/69 setup ( which includes the map light ), which will give you the idea on how it looks the time delay flasher and how is wired down the dash You should find something similar
Thank you this form is the best. Helpful people.
