rumblefish360
What is the single most beneficial component you have added that improved the handling or ride of your Mopar?
In this order but best when all 3 are done at once for a real punch in the nose noticing!
Bigger anti roll bars (sway bars)
Use with superior compound wider tires.
Upgrade your shocks.
If, after this, your cars up and down amount feels excessive, then bigger T bars. But not until then. Most factory T bars are right within that comfortable zone for most driving conditions.
T bars control the body/nose’s up and down movement and to a degree, the body roll in turns. The anti roll bars should take care of most of the body roll.
The icing would be the subframe connectors.
There best use is with higher powered cars. But you will feel a difference with there installment on your normal powered engine.
