Mike Gaines
- 4:41 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Can you possibly fabricate a steel or aluminum "extension" to the bottom of each ear of the motor plate which would actually "raise" the motor by the amount of the "fabricated extension" that you bolted to the bottom of each ear of the motor plate...??I am still fighting the clearance issue I had the motor in 3 times an have clearance issues with my tie rod and the pan. When engine is in I have a 3 degree slope and I can't lower the front fur to the tie rod. I raised the rear of the trans but my blanket is so tight it won't move much
Suggestions ????
But I guess that might change the drive shaft angle too much ....by raising the front of the motor ?? Don't know how critical that is.
Best way I guess would be to get a pan that would accommodate the tie rod...but that might be hard to come up with. You might call Milodon and Moroso and see if they have a pan that would solve the problem.
My Oil pan hit my tie rod by just a little bit....so I took a steel pipe a little bit bigger that the tie rod, laid it on the pan, heated up the pan and tapped on the steel pipe and "indented the pan" by about 3/8" of an inch, enuf to clear the tie rod but not too much where it interfered with the pickup in the pan.
