HEMI-ITIS
STREETER on LI
- 3:58 AM
- Dec 14, 2008
- Long Island,New York
Your SFI just expired
heres what i have....572 hemi/68 pro-street roadrunner
keith black aluminum block
scat 4340 non-twist forged crank
oliver billet steel race rods
J E 11.5 to 1 pistons
bullit flat tappet solid cam 283/283 duration @.050 711 intake/690 exhaust
schubeck composit lifters
smith brothers push rods
stage v big valve heads 2.40/1.94
comp port and polished by tim...forhemisonly
stage v 1.6 ratio roller rockers
billet rocker stands
milodon swing gate dual line system
milodon 9 qt pan
milodon gear drive
msd distrib and 6 al
tti 2 1/8..3 1/2
indy tunnel ram
2-1050 pro-system dominators
meziere electric water pump
taylor 10.44mm wires
ati super damper
727.. cope tranny
PTC 9...3800stall convertor...
mark williams chrome moly shaft with hd joints
dana 60..4.30 gears.. moser axles
29.5/13.50-15 mt slicks
8 point cage and frame connectors
mini tubbed/super stock springs moved in 3 inches
mallory comp 250 fuel pump
areomotive billet fuel pump controller
triangle 20 gallon fuel cell
RAN 10.37/129MPH.....3900LBS
Lol. Nice car.here is a pic of my 65 plymouth that i wish i would of never sold. should of sold the X wife instead.lol
A bunch of the Gentry Brothers gang put that car together for Wendell Franklin, we talked "Moby" radio Wildman into coming down to the old Freeway drag strip, HIR, and make a pass in the car bearing his name. We all had a blast and he was on cloud nine.440 stock block and stroke, Hemi rods, ash can Jahns pistons, 11.2-1, Isky .660 lift roller with all Isky valve train, non roller rockers, Weiand tunnel ram with 750's, 906 max ported heads, 214/1.88, 2" hooker race tubes, modified 727 w/4500 stall, Dana 60 and 4.88's. This was in a 3200 lb 68 Road Runner back in 84. Ran 10.68 @ 126 shifting at 6800 and crossing at 7300 with 12.5W Firestones.
Yup...wasn't there for that run but the car's name was Moby before the DJ came to Houston iirc. I remember seeing the name on the hood scoop in block letters and then once the DJ drove it, the name was added to the doors.....right? Man, that was a long time ago lol. I bought the car after after someone won it in a raffle. I'll remember his name if I sit here long enough....it was Jason Hamner's step dad if my memory serves me right. And you're the same guy that owns Rustic Window & Shutters?A bunch of the Gentry Brothers gang put that car together for Wendell Franklin, we talked "Moby" radio Wildman into coming down to the old Freeway drag strip, HIR, and make a pass in the car bearing his name. We all had a blast and he was on cloud nine.
The MAJOR TUNEUP was installing a motor with 300.more HP...lolYes congrats Mike on tuning your Mopar to run so good ! Ron
Here's my 10 second combo:
440 stock block .055 overbore
Wiseco Flat tops
Eagle 4.15 crank and H beam rods
Indy Little EZ 295 cnc ported heads 65cc's
Comp Cams Roller .620 lift 272/276 @.050
A&A Max Wedge Crossram ( the 100hp killer)
2 Eddy 750cfm carbs
TTI 2" headers, X-Pipe, and Magnaflow mufflers
ATI 8" Treemaster converter 5400 stall
727 Trans with A&A aluminum front drum
Dana 60 rear with 4.30 gears
M/T 29.5x10.5 bias slicks
Car weight approx 3380lbs.
Always raced thru the mufflers
