Sneek peek at my 588 Indy motor
indy 440-25 crossram intake installed
finally got the correct flexplate from mancini racing. after they made another mistake with my order, it finally arrived yesterday. so i'll put that on tonight and it will be ready to drop in over the weekend. WEATHER PERMITTING AGAIN.
I took 1/2 the day off today for the 1st time in a long time.
I had to get my mind off of things. I lost my best childhood friend last night.
So I came home early and put the 588 in my blue Dodge today and started putting parts on.
Played around and put some more parts on the 588 today. Here are some pics. I needed some alone time today. I'm pretty shaken up.
empty engine bay.
a little more progress, just dropped 25 degrees, im done till tomorrow.
a few more.
Looks like I have to move the remote oil filter, cant get the oil lines on with the Moroso Oil Accumulator in its new location.
looking good chris, make sure you put that bolt back in the flex plate before you put the trans in.
Thanks, new 1/2"-20 ARP Bolts are in the crank holding the flexplate.
Got alot done today considering my frame of mind.
Put in my new turbo Start 16 volt battery and charging receptacles in the back of the car for charging.
Here's a few pictures of the new bullet. It won't be long now.
588 will be fired up tomorrow. Ran out of time now. Its all buttoned up and i'm really pleased on how everything went together.
Its off to the paint shop next week and then my parachute mount is getting welded on.
pics and video to follow tomorrow.
WEll it's all done.
Everything lined up great. Got the new CSR Trans. shield in and new Star Vacuum Pump installed.
I also went with a Turbo Start 16 volt battery and a Product Engineering 16 volt Alternator when I have to go rounds.
Clinton (440gtx) doesn't need an alternator since he doesn't go past 1st round. lol
New Turbo Start 16 volt battery install.I also went with the Miller welding female sockets in the back tail panel for charging between rounds.
pics of new battery
