Ordered Slicks/Rims
I run Hoosier 30 x 9 radial slick. I have actually been driving on the street with them for over a year. The letters stayed pretty clean. And mine hold air great without tubes. They held all winter without leaking down any. Ron
I think I need the same size on my 67 as you have.
I put the 11.5 Hoosiers on my car only to find they're just too wide! Does your slick have the two grooves "tread" cut around the entire tire "DOT"?
Thanks...
Thanks...
FWIW- if the front of your wheelwell isn't cut you won't fit the 9 x 30 tire.
I have completely stock openings and the M/T 9 x 28 slick or the M/T ET Street 11.50 x 28- with the grooves (DOT approved) fit and work perfectly on my 67 Belvedere.
I weighed the other rims/tires. They are only 5 lbs per side lighter. Problem is I am using the 8 ply M/T's on the front. I was going to use the car for street driving so that is why I went with those. I am thinking about selling them and getting a set of front runners. That would be 13 lbs less per side then.
The loss of 1lbs of rotating weight = 9 lbs of dead weight.
My wheelwell's are stock as they have never been cut. I did install a 65 B-body rear but thars all. I am using the 30 x 9 slicks with no tread groves. I wanted a drag radial with two groves but no one makes a drag radial in the 30 x 9 size which is what I like to run so for now I use the slicks. Ron
