need help oil issue 400 cid
funnycar
1:48 PM
ankeny iowa
well built a 451 stroker everything new and or machine so were not working with used parts
went to prime no problem 80 lbs of pressure at bottom end
problem no oil comming out the rocker shafts
removed shafts still no oil comming out new oil pump new cam bearings shop installed not my doing
my guess number 4 cam bearing has issues tell me im wrong
thanks for you help
I had the same thing happened with a 340 a few yrs ago. I turned the crank a little and the oil started flowing. I'm thinking the oil channels wasn't lined up.
Yup, if the oil channel in the cam is not aligned with the oil feed hole, no oil will make it to the top. And the cam only feeds one side at a time so you need to rotate the engine for that to happen.
400 motor
good call guys
yes rotate engine and the hole comes out 180 it again on the cam and it took care of the side
thank you very much
Doesn't the full groove bearing help prevent this?
Actualy, I think some have grooved the camshaft journal......
Assuming you have a fully grooved cam bearing but I haven't seen or heard of anyone running one. That would cause too much oil up top anyway.
What I had seen was a fully groved camshaft journal, not the bearing itself.
I dont think it lets the full amount of oil go through, just a portion of it that slips through the groove. The full amount would only be available when the hole lines up, just like stock would be.
