bigmanjbmopar
Newb with a view
initially we went with a full turn on the valve adjustments and got lock up, then backed off to 1/4 turn and it seems fine, then one day while checking a compression tester we saw 45-50 lbs of comp?? way low should be up to 110+ right? Seems we thing the valves are still too tight. would backing off to 1/8 of a turn or less work to bring it back up? No other real problems other than crappy eddy 800 and little tweek on the timing.
