69 Bee Clone new puchase needs work
See if you can find part numbers on the springs, they may be the Police or Hemi suspension springs. What is the V.I.N. of the car as it will tell you what model and engine the car was built with.
X2^^ Which side of the car has 7 leafs...?
Well...the passenger side should have the 7 leaf spring if they're Hemi/Police...did you happen to get a number off them?
Yep thanks for that, I intend to swap them around.
can't find any numbers, though I have not had time to look properly yet.
Gunna job......
Hi Fella's, been workin on the electrics today... am I pissed at what I found!!!!!!!!! no wonder nothing works??????????
Like to try and get some advise and maybe some help with parts???? if someone can help???
2 main problems that I can see straight away are....The stripped and broken wiper plug...and the dome light switch total shagged...
here are some pic's....like to buy these bits? if someone has some spare..
or maybe a replacement underdash harness????
Looks like you need some new stuff.
The melted connection plug usually means something is drawing too much power. I have seen it with heater fan motors and I am assuming this is the plug for your wiper motor?
I am just guessing here but I'd say there is a good chance your wiper motor needs a rebuild. I suppose it's possible too that the wiper motor became stuck and the switch was left on with the wiper motor stuck.
Either way I'd have a look at that wiper motor rather than just repairing the connector.
The scrolling wheel or "dimmer" type roller switch must be a weakness in these old mopars because the one in my 69 roadrunner is junk as well.
