Race Cars in Progress
Very nice,even for a race car that looks fairly comfortable.Nice trim/tin work.
A little more progress on the charger.Finished up the funny car cage and drivers door x brace.Mounted the dash,have to finish trimming the dash pad.Need to add a couple of braces and the drivers compartment is done.
Been working hard on this ol thing. Should be out in the spring...I hope.
Thanks man. It's going to be a .030 over 440 (11:1 or so) with a new set of MP iron Max Wedge heads. I am going to use the stock cross ram for now. I will eventually put an Indy bathtub on it. I've got a set of 3705's to go on top as well. I will be tickled if the car runs mid 10's. I hope it goes faster but if I can fit in NSS/B that would be grand!
I got a similar build 440 0.060 over indy max wedge ez full cnc roller cam single carb setup 10.77@123.8mph best 3700#race weight.Stepping up the converter a little and a little weight loss.We will see.
What gear are your running? What's the cam specs?
Thanks!
4.30 gear 29.5 tire. Cam is 648 lift and around 270 duration@0.050 its a little over 11.1cr.Bracket racing shift at 6300 runs 11teens.Flogging it shift around 6800rpm.This is all on 93 octane through the mufflers.
Just about finished the cage on the charger.A couple of small reinf bars and final welding and the cage is done.Then my favorite tin work:BangHead: I enjoy sheet metal fab,hell I dam near made the right fender by hand.Tin work I hate it!!!!
Moparpoor that's looking real nice
Buckeye that's looking sweet, is that Wally in your avatar yours ?? what class & race did you win it for ??
Thanks for the compliments!!I really need to get this done so I can work on my 64 dodge.Then on to the darts!
Your very welcome
Your welcome, I have only one real project my 68 RR, it's only a resto-rod now, not really a race car, at all... well 2 car projects I guess my 68 RR & 99 4x4 Dakota little add on stuff, I can't seem to get anything done lately.... Life gets in the way sometimes...
Man I wish I lived closer to you Moparpoor Id see if you could do my cage/chassis lol Looks good, im jealous
I have to finish the charger up soon as possible.I have my 64 wich needs a major overhaul before race season.How about some ideas for a paint scheme or even a vinyl wrap!
Wow that is really a nice 63 you are building. Course I have a soft spot for 63's. :hello2: Ron
