seam sealer question , drip rails and trunk .
rav440
12:38 PM
cranberry twp. pa.
i have a question about seam sealer . what kind of seam sealer did you use on the drip rails between the roof and door glass ? my was filled from the factory .
also restoring the trunk did anyone put the seam sealer back if so how much did it take and what brand brand did you use ? or just give it the clean look ? alot of it will be unseen due to the trunk mat .
if anyone has pics of both ways that would be great .
thanks RANDY
Randy....
For your drip rail seam sealer, I would use 3M heavy-Bodied seam sealer.
http://solutions.3m.com/wps/portal/3M/en_US/3M-ESPE-NA/dental-professionals/products/espe-catalog/~/3M-Heavy-Bodied-Seam-Sealer-08308-200-mL-Cartridge-6-per-case?N=4294934372+5144829&Nr=AND(hrcy_id%3AGSP4VS0F4Qgs_7P66KVM5BP_N2RL3FHWVK_GPD0K8BC31gv)&resultsPerPage=90&rt=d
For your trunk I would definitely use a seam sealer...Any little gap/lap moisture can get in, seal it and seal it good. The 3M brushable works ok..kinda thick, but I have much better luck with the Evercoat Brushable seam sealer. Flows better, paintable
http://www.evercoat.com/productDetail.aspx?pID=51
3M, SEM and Evercoat also make the standard seam sealer in a caulk tube as well.
Just what has worked for me...........
thanks . i want the trunk to look like it was factory so i will use the evercoat and brush it on .
Randy....
PROPWASH , can the 3M 8308 be used on bare metal or should it be primmed first ? or should i go with the 8310 ?
That can be applied directly to bare metal Rav440.
"Heavy-bodied, non-sagging, non-flowing, and easy tooling formulation for matching OEM seam sealer appearances. Appropriate for bare metal applications."
the best seam sealer for price and durability is the stuff from napa - i think its their own brand name - works fantastic. I've tried the 3m, not as impressed..
